Latest: Mr-Koekwaus
Overall: 17125
Online Now [67]:
Visitors: 66
Today: 24257
Total: 99383938
Forums › The Car › 206 Talk › Did these alloys come standard on the 2001 206 HDI D turbo
Imelliot
PostPosted: Sat Nov 29, 2014 4:43 pm Up
I know these are 206 alloys just wondering if they came standard on this specific model of 206 so i know what to tell my insurance Razz
2001 206 2.0 D-turbo HDI
[img]
[/img]
PostPosted: Sat Nov 29, 2014 5:23 pm Up
Nope and they don't look like Peugeot wheels.
Imelliot
PostPosted: Sat Nov 29, 2014 5:27 pm Up
I'm sure i've seen other 206's with these wheels and it has the Peugeot hub caps.. Well on the other side at least. I'm assuming these came with steel wheels then?
PostPosted: Sat Nov 29, 2014 6:00 pm Up
Servicebox tells you what the vehicle left the factory with. If it says in the characteristics that it left with steel wheels, then they may have been an option.
Those look very similar to mine which I believe are 14" Tornado allotys
Imelliot
PostPosted: Sat Nov 29, 2014 6:28 pm Up
They look identical to yours and they're 14" i believe and thanks i will check it out Very Happy
Imelliot
PostPosted: Sat Nov 29, 2014 6:38 pm Up
Servicebox won't load at all for me. Was thinking of contacting my local Peugeot dealership to see if they would be able to tell me with the VIN number. Not like it really matters will be putting a set of GTI alloys on it anyway so i would need to tell the insurance about them. Wonder how much that will add Sad
PostPosted: Sun Nov 30, 2014 2:43 am Up
Service Box is normally taken down on certain weekends when Peugeot are updating the service.
It will be back up Monday morning at the latest.
