Latest: DanDan17
Overall: 17128
Online Now [101]:
Visitors: 100
Today: 20809
Total: 100418979
Forums › The Car › 206 Problems › Brake Servo ?
Brake Servo ?
n17ele
PostPosted: Mon Dec 01, 2014 11:40 am Up
Hi
My car does not always have servo assisted brakes ! Sometimes the brake assistance is not there and have to press really hard for them to work. I can not hear any hissing from a leak. The vacuum pipe is the hard plastic pipe so would not think it has collapsed ?
I also have the problem with car not ticking over, could this be linked.
Was thinking of taking the servo vacuum pipe off and blocking the hole to see if the car would tick over ( not drive it like that ) Is there a non return valve that could be broken? although if not leaking I can not see that making much difference
Any ideas
PostPosted: Mon Dec 01, 2014 11:43 am Up
There is a valve that goes between the servo & the vacuum pipe.
n17ele
PostPosted: Mon Dec 01, 2014 12:35 pm Up
Thanks. Mr BSI
I assume that's all in the pipe ? Is the vacuum pipe screw on or push on connection ( its a 2006, 206)
Forgot to say it is petrol 1.4 8v
