Latest: Andyblue64
Overall: 17123
Online Now [489]:
Visitors: 488
Today: 35186
Total: 98546565
Forums › The Car › 206 Problems › Climate control problem
Boydie
PostPosted: Thu Feb 07, 2013 4:06 pm Up
hey all
my Climate control is really doing my head in. every time i start the car the ac comes on straight away is there anyway that it can be set that eco is always on?
Gti 180
PostPosted: Thu Feb 07, 2013 4:24 pm Up
Its supposed to do that.
live with it.
Boydie
PostPosted: Thu Feb 07, 2013 4:31 pm Up
thats abit of a bad design who the f*** would want the ac on everytime they get into the car :s
Gti 180
brad-morris
PostPosted: Thu Feb 07, 2013 4:41 pm Up
Mine stays on most the year, it clears all the humidity in the car.
Quikrex
PostPosted: Thu Feb 07, 2013 4:45 pm Up
I was actually researching the same thing it's rather dumb if its by design lol oh well guess I will deal with it.... But mine only goes to ac if left over night or a good few hours otherwise it stays at the same heat fan speed and Eco mode if I leave the car for a couple hours.
brad-morris
PostPosted: Thu Feb 07, 2013 4:47 pm Up
If thats true then it seems like a good design by Peugeot, having the AC when your screen is condensated clears it alot quicker than just hot air.
PostPosted: Thu Feb 07, 2013 6:07 pm Up
Im sure ive read somewhere that 3 consecutive starts with the same settings becomes its new default.
PostPosted: Fri Feb 08, 2013 10:43 am Up
Another pointless thread due to people not understanding how climate control works Rolling Eyes
Just leave it set to AUTO & change the temp setting when needed.
Boydie
PostPosted: Sun Feb 17, 2013 2:06 pm Up
have a look at the name of this website "206INFO" people come on here to get info about their car not for knobs like you to have a go at them not understanding how things work. if your going to be getting on like that then you shudnt be on this website Confused
Gti 180
PostPosted: Sun Feb 17, 2013 2:17 pm Up
Why even buy a car with climate control fitted if your just going to moan about it Rolling Eyes
If you had bothered to actually RTFM you would understand the climate control systems functions Whistle...
Boydie
PostPosted: Sun Feb 17, 2013 2:25 pm Up
didnt care if there was climate control on it or not before i bought it. and im not moaning about it only asking a question as thats what people do on this site
Gti 180
Deckchair5
PostPosted: Mon Feb 18, 2013 2:49 am Up
If you have the A/C turned off so it displays ECO and use the OFF button to turn off the climate control at the end of your journey but then use the OFF button again to turn it on the next time you start (rather than AUTO) then it will retain and use your previous settings. If you hit AUTO then you are giving the climate control total control to do whatever it needs to quickly get to and stabilise the temperature you have set and it will turn on the aircon automatically to help it do that
Similarly, if you hit the front demister button then the A/C will be switched on for an automatic rapid demist
An exception is when the outside temp is near freezing and then the A/C won't be allowed to start in order to prevent internal damage
cat41
PostPosted: Sat Dec 13, 2014 5:33 pm Up
Hehe this just made me laugh, i just posted a similar question, i hate the air con coming on automatically, but just see an interesting reply on your post, setting the air con off, i will try that tomorrow.
I also saw a few replys stating live with it so on, thats not too helpful when you are arking a simple question, i say this, if they arks a question about their car say live with it back lol.
PostPosted: Sat Dec 13, 2014 5:49 pm Up
You'll just have to live with it.
mattymj
PostPosted: Sat Dec 13, 2014 6:57 pm Up
When i first get in i put the ignition on. Look to see what the climate control is on and adjust it accordingly before i start the car. Owned it for 10 years and seems the best way for me.
