Latest: DanDan17
Overall: 17128
Online Now [59]:
Visitors: 58
Today: 30347
Total: 100505113
Forums › The Car › 206 Problems › ABS and speedo issue - GTi180
s3tre2003
PostPosted: Mon Jan 05, 2015 5:18 am Up
Looking for some help on behalf of a friend
His 180 is light up like a christmas tree.. all the lights are on on the dials and flashed up with an ABS fault, Handbrake on and depollution error
Ruled out the battery.. all reading are fine on that
Has 2 error codes:
P0502
U0121
Now having had a search it seems it has lost communication to the abs ecu (or whatever the correct name is)
Soo.. the question is what would be the next step? Can this be replaced? If so how? Where is it located etc...?
206 Number 6 - 55 Plate 1.6HDI Sport (Daily Workhorse) - NOW SOLD
206 Number 7 - 04 Plate 2.0 HDi to use for some mile crunching!
207 GTi THP 175 - Shark Grey
PostPosted: Mon Jan 05, 2015 2:25 pm Up
Well since there is no communication between the ABS ECU,and the Engine ECU (U0121),and the fault (P0502) which is for vehicle speed sensor,I would check the (BSM),which is the fuse box in the engine bay,check it for these:
1-Check fuses,all of them,and the one hidden under the BSM.
2-Check it for water,if there is any kind of water marks.
if there is water,dry it,and spray some contact cleaner,and see how things goes,hope that this will help your friend.
Good Luck
PostPosted: Mon Jan 05, 2015 2:32 pm Up
Hasn't had w**ky aftermarket HID lights fitted by chance?
s3tre2003
PostPosted: Tue Jan 06, 2015 3:01 am Up
It does have HID's fitted i believe?
I think he's been through the fuses and all are dry n fine..
PostPosted: Tue Jan 06, 2015 3:10 am Up
That's the problem then.
s3tre2003
PostPosted: Tue Jan 06, 2015 6:53 am Up
Just Remove them?
PostPosted: Wed Jan 07, 2015 2:50 am Up
s3tre2003 wrote:
Just Remove them?
Yes,unplug them,and give it a try,but MrBSI,would the HID kit cause problem even if the lights is off?
gpvecchi
PostPosted: Wed Jan 07, 2015 2:40 pm Up
Do the HIDs give problems even when off? Could they give issues without P codes and/or faulty lights?
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
