Online Now [230]:
Visitors: 229
Today: 24095
Total: 140130847
Forums › The Car › Request a how-to › rear calipers not working how to service myself
Forum IndexRequest a how-to
cat41
PostPosted: Sun Jan 11, 2015 11:13 am Reply with quote Up
Hi all.
It's looking if the left rear caliper isn't working at all, with handbrake full on a can spin the wheel, also i,ve been out then put my hands on the discs, the rear left is stone cold, the rear right is warm.
I used to service my motorcycle brakes years back and i see the cars ones looking ok to sort.
Any tips on how to keep these calipers alive and kicking?
Its a 1999 gt
Project2062014
PostPosted: Mon Jan 12, 2015 1:36 am Reply with quote Up
Got loads of fluid isn't it ? No split in brake line .
Take calipers off give clean around the pistons check they move ok ¬ stuck . . Check there is no air in ,or a blocked brake line or leaks.
rear right does stick a little on mine .
Left rear always seems weaker on handbrake (rally drifts ). handbrakes are weak on a 206 for sure .
cat41
PostPosted: Mon Jan 12, 2015 4:13 am Reply with quote Up
Thanks for that info.
Is there any way to improve the rear brakes and manly around the handbrake.
PostPosted: Mon Jan 12, 2015 4:29 am Reply with quote Up
A pair of service / exchange calipers.
The calipers if not looked after are a known weak spot.
cat41
PostPosted: Mon Jan 12, 2015 4:32 am Reply with quote Up
I,m buying a spare set of calipers but will make some tweeks, i,ve got some ideas i will try.
Project2062014
PostPosted: Mon Jan 12, 2015 6:22 am Reply with quote Up
Tighten the hand brake cable .
cat41
PostPosted: Mon Jan 12, 2015 7:18 am Reply with quote Up
Its on 3 clicks,
PostPosted: Mon Jan 12, 2015 8:20 am Reply with quote Up
The calliper need's replacing, the handbrake mechanism inside will be rusted up - common problem with this design of calliper if there not looked after correctly.
macj
PostPosted: Mon Jan 12, 2015 2:05 pm Reply with quote Up
I have standard GTi rear calipers on the rally car, The cable handbrake just makes MOT standard with new discs and pads but the hydraulic H/B is very good. Locks up both rears every time...... but that's cheating Wink
cat41
PostPosted: Mon Jan 12, 2015 2:17 pm Reply with quote Up
Do that just bolt on mine and are able to be used with the handbrake, its far too much work now
macj
PostPosted: Tue Jan 13, 2015 2:18 pm Reply with quote Up
You need to re-plumb your whole system Shocked
cat41
PostPosted: Tue Jan 13, 2015 2:22 pm Reply with quote Up
I,ve just fixed the airbag issues, tomorrow its the rear calipers, i,ve strayed wd to help free up the stuck bolts, i stand a good chance in bringing them back from the dead, i used to service motobikes brakes and a cars not too dissimilar. I give it a go anyway.
  Quick Reply
Username:
Message:
Quote the last message
