Latest: Mr-Koekwaus
Overall: 17125
Online Now [118]:
Visitors: 117
Today: 10535
Total: 99395789
Forums › The Car › 206 Talk › 206 GTi 138 - Clutch Recomendations
PostPosted: Tue Jan 13, 2015 3:19 pm Up
03 plate GTi 138, I think my thrust bearing is on the point of shitting itself big style. Started making some extremely horrible noises last night. New clutch kit time.
Just wondered if anybody had any recommendations on a decent clutch kit for it?
Also is there anything else I should be replacing whilst I have the box off apart from the driveshaft seals?
Regarding the flywheel I know it would probably be best to whip it off and give it a skim. But I do have a 180 flywheel sat in the garage, would it be worth me getting that cleaned up & skimmed and throw that in with it instead? Or should I just stick with the standard 138 flywheel?
Thanks for any input Smile
PostPosted: Tue Jan 13, 2015 3:36 pm Up
LUK, Valeo or Sachs for the clutch kit.
PostPosted: Tue Jan 13, 2015 3:37 pm Up
Been looking at the Valeo kits. Seen a Valeo kit for £78 delivered.
PostPosted: Tue Jan 13, 2015 3:42 pm Up
Valeo was most likely what it rolled out the factory with originally Wink
Cant really go wrong with any of those 3 brands, there all decent quality.
PostPosted: Tue Jan 13, 2015 3:47 pm Up
It's still on the original clutch at 98K, the thrust bearings been making a noise since I bought the car, I knew it was a job coming before I even took ownership. Just a shame as the clutch itself isn't slipping. But I'd rather get the job done & out of the way in my own time so I can avoid the hassle of it leaving me stranded on the side of a road miles & miles away from home.
Any advice on the flywheel?
PostPosted: Tue Jan 13, 2015 3:51 pm Up
Flywheel - I've never had to change one, normally they clean up ok with a bit of brake cleaner.
Not sure if your BE box is similar to the MA but I do remember also changing the input shaft bearing, bolts on to the outside of gearbox.
PostPosted: Tue Jan 13, 2015 3:57 pm Up
Might just give that a go then, will have to find the numbers for the flywheels and see if the 180's significantly lgihter to warrant changing it.
And regarding the bearing, would that be number 2 here....
inputshaft by LeeThr, on Flickr
PostPosted: Tue Jan 13, 2015 4:05 pm Up
Have a look at Peugeot part number 2105 35 - Clutch Buffer Guide bush £17.59.
PostPosted: Tue Jan 13, 2015 4:15 pm Up
Found it
buffer by LeeThr, on Flickr
Will get one of them as well ready for when I drop the box.
PostPosted: Tue Jan 13, 2015 4:18 pm Up
Always worth changing when doing the clutch kit, they do wear a fair bit & get damaged over time.
PostPosted: Tue Jan 13, 2015 4:20 pm Up
Okie dokie, thanks Smile
Need to do the timing belt as well, Thinking it might make life easier if I pull the box off then do the belt as I'll be able to move the engine further over for more access.
PostPosted: Tue Jan 13, 2015 4:29 pm Up
Sounds like a plan Wink
PostPosted: Tue Jan 13, 2015 4:45 pm Up
And don't worry I wont be making a thread about not being able to lock the engine in place Razz I have access to a set of the Laser Timing tool kit for the EW engine Wink
PostPosted: Tue Jan 13, 2015 5:43 pm Up
You need to fully strip the box to access the input shaft bearing. BEs have no issue with the bearing though mate
Just dont loose the washer behind the nose cone!! Ive bloody done it and killed my paddle clutch! They are £46 plus vat as well
PostPosted: Tue Jan 13, 2015 6:15 pm Up
Cheers, will make sure I keep my eye on that one then. You got any input on what I do with the flywheel? Do I just clean up the 138 one or do I throw the 180 one in?
