Online Now [98]:
Visitors: 97
Today: 10630
Total: 143137145
Forums › The Car › Solved 206 Problems › 04 206cc turns over wont start
baker9076
PostPosted: Sat Jan 24, 2015 6:27 am Up
Hi I have got a 206cc 1.6 it will turn over but won't start any ideas please thank you regards chris
PostPosted: Sat Jan 24, 2015 8:35 am Up
Can you see the camshaft if you take the oil filler cap off? Does the cam turn when the key is turned?
sean.r.steward
PostPosted: Sat Jan 24, 2015 8:57 am Up
Crank sensor
sean.r.steward
PostPosted: Sat Jan 24, 2015 9:00 am Up
Sorry should say more. Check you ingredients chef lol
Fuel/pump
Air flow
Spark/crank sensor
Scan codes
Hope you find a solution
