Posted: Sat Jan 31, 2015 6:03 am |
hello guys some of this stuff come in our country from japan look like wrc but non wide, but quite rare nowdays , is anyone what its its called to be exact and any chance to get it ?
[img]http://i.ebayimg.com/00/s/NTU4WDc5NA==/z/79wAAMXQlUNRIrB8/$T2eC16d,!yEE9s5jGLRSBRIrB8TgMQ~~60_58.JPG[/img]
Posted: Sat Jan 31, 2015 7:42 am |
It's called hideous.
Posted: Sat Jan 31, 2015 8:17 am |
Posted: Sat Jan 31, 2015 9:29 am |
my gosh.. looks like cat sick. Im off to bleach my eyes.
Posted: Sat Jan 31, 2015 9:53 am |
Posted: Sat Jan 31, 2015 11:32 am |
if your going to go wrc you'd be better off fitting the proper wrc wide arch version
Posted: Sat Jan 31, 2015 1:01 pm |
| MattyP wrote: |
| if your going to go wrc you'd be better off fitting the proper wrc wide arch version |
Wont happen here 3 door are limited here.. Mine was 5 door with gti engine, bet just using stock bodykit
Posted: Tue Feb 03, 2015 9:49 am |
Posted: Tue Feb 03, 2015 3:29 pm |
Posted: Tue Feb 03, 2015 3:31 pm |
Buy wide boi kit & cut it up . DONE !
| If it aint broke dont fix it ! | |
