Latest: williamekstrom
Overall: 17124
Online Now [203]:
Visitors: 202
Today: 14903
Total: 99306763
Forums › The Car › 206 Problems › Runing gti 180 on gti 138 exhaust system??
scoop
PostPosted: Mon Feb 02, 2015 12:55 pm Up
Hi guys, i have a 206 gti 138 which i upgraded it with a gti 180 engine, so the question is will it run good with the standard gti 138 exhaust system, also could i decat without causing the check light on? And finally i have a faulty secondary air pump malfunction, could i dissable it via peugeot planet 2000?and what are the steps for dissabling it? Thanks
ahmed
PostPosted: Mon Feb 02, 2015 1:05 pm Up
You cant disable the air pump as its used for the emissions. And personally i wouldnt advise it as most of the power comes from the inlet and exhaust manifold
And no again for the decat unless you have a lambda sensor extender
scoop
PostPosted: Mon Feb 02, 2015 1:14 pm Up
So you mean i could use my standard gti 138 exhaust catalyzer pipings and mid muffler and rear muffler??
ahmed
PostPosted: Mon Feb 02, 2015 2:22 pm Up
Possibly if it fits but you would LOOSE a good amount of power. Just buy a manifold and centre section
Project2062014
PostPosted: Mon Feb 02, 2015 5:40 pm Up
Yes decat it & use a lambra extension use the one thats L shape @ 90 degree .
you could use the gti exhaust . Just check the cat to manifold or decat pipe to manifold connection . As i think its smaller .
Gti exhaust pipes have a smaller diameter than a 180's .
56/57 mm on gti 59/60 mm on 180 (ish)
PostPosted: Mon Feb 02, 2015 6:29 pm Up
Why go to all that trouble then not change the exhaust?
After all it was designed with the engine in mind
scoop
PostPosted: Mon Feb 02, 2015 10:00 pm Up
Its already fitted, but i dont know if there is power loss, and here in egypt i cant find gti 180 exhaust system, but i dont know what is meant by lamda extender? Any link to that? Or pics?
ahmed
