Posted: Sun Feb 01, 2015 12:25 pm |
Hi, new to forum.just bought a 1.4 206 1.4 sport 55plate, had it since October.
Central locking has just stopped working !
It isn't the key fob even though I have changed the battery as the indicator lights do flash on off when I use the fob. None of the 3 locks work so I am locking each door manually, it just leaves the boot always open as it doesn't have its own key lock.
I've tried resetting the bsi twice using instructions from the web but this hasn't changed anything. All three locks don't work. I can't believe all three solenoids have failed simultaneously ? I think its got to be a fuse or wiring ? I don't want to take it to a garage just yet. Any help on this issue would be much appreciated.
Posted: Sun Feb 01, 2015 3:10 pm |
This topic have been covered many many times in here,please search and you will see how many topics have central lock involved,but it's easy to check the fuses under the steering wheel,take the cover off,and test each fuse by a voltmeter.
Posted: Wed Feb 04, 2015 4:25 pm |
Thanks for the info. Would it not be easier just to check the fuse associated with the central locking ? If someone could tell me the position of this one ?
Posted: Wed Feb 04, 2015 4:45 pm |
Posted: Mon Feb 09, 2015 3:04 pm |
Tested the fuse and this isn't the problem. I even put in s new 30amp one but the central locking is still not working. Any further ideas on this matter would be much appreciated before I start shelling out cash on an electrician.
