Online Now [106]:
Visitors: 105
Today: 87764
Total: 139962816
Forums › The Car › Request a how-to › Open chrome lexus back rear tail lights
Forum IndexRequest a how-to
ToskeGV
PostPosted: Wed Feb 11, 2015 6:08 pm Reply with quote Up
one of red plastic is broken(bought car like that) so i want to fix it but i dont know how to open this up Smile
any advice?
images.esellerpro.com/...L4002A.JPG this model Smile
Vexs
PostPosted: Wed Feb 11, 2015 6:33 pm Reply with quote Up
These are designed not to be opened up at all, but doesn't mean it isn't possible.
You have 2 options:
(Remove the bulbs and any loose fittings, screws etc before using either method.)
1.Use a heat gun/ hairdryer on a high heat around the edges to re-activate the glue then pry them apart.
2. Pre heat an oven to around 160-180 and bake the lights for 5mins at a time.
Remove after 5mins and try to pry apart, keep doing this until succesfull.
NOTE: keep the lenses away from touching anything whilst baking.
To re-seal them you need to remove all the old glue and have a clean surface to work from. Use either a waterproof sealant or a no nails like sealant to ensure a water and air tight fit.
I don't honestly recommend splitting them and don't take any responsibilities for what you do to them. You will almost certainly suffer from misting/ condensation issues in the long run.
These lights can be bought for around £10-20 second hand and around £30 new for a pair. Splitting them is a lot of hassle and isn't really worth it; especially as they aren't very desirable.
My GTI 180
My Old 1.4 8v
ToskeGV
PostPosted: Thu Feb 12, 2015 10:45 am Reply with quote Up
Well here in Serbia thay are around 50E if you find them Smile And actualy i like them so i want to try and fix them Smile tnx for advice Smile
and new are 99E :S
  Quick Reply
Username:
Message:
Quote the last message
