Posted: Sat Feb 14, 2015 10:55 am |
Hey guys new to this forum. I have been searching the web but can't seem to find the right answers. My girlfriend has a Peugeot 206 HD (X-Reg) with well
Over 100,000 miles. Until the past year the car has been reliable with a few hundred quid being spent here and there. However today she tried to start the car and it wouldn't start, plus all of the dash started to go crazy. The speedo and rev counter were going up and down and the lights were all flashing. I am sure we are going to get it to a garage some how on Monday but in the mean time we are wondering if this is going to be a big fix?
Bloody French electrics, lol
Lloyd
Posted: Sat Feb 14, 2015 11:55 am |
Check the main battery earth lead where it attaches to the top of the gearbox & then on to the body.
They are known to come loose & / or break.
Posted: Sat Feb 14, 2015 12:32 pm |
Just sounds like a flat battery
Posted: Sun Feb 15, 2015 2:58 pm |
Hi guys im having the same problem, my 206 wouldnt start. i jumped it wile its running the dash lights go crazy and flash its beeps at me but nothing comes up on the display the dials on the fuel guage go up and down the dash lights go out but the airbag light stays on. i put it in gear to move off but as soon as you take your foot off the clutch and apply the throttle the engine dies can somebody help please a friend suggested it may be a crank shaft or cam shaft sensor could this be true? Many thanks
Posted: Sun Feb 15, 2015 3:16 pm |
well check the earth strap,as MrBSI said,if all is good,then you need to check your battery,if you hear a "Bong" sound when you turn the ignition on,then you need to replace your battery.
as for (Paulhiggins84),if the crank shaft or cam shaft sensor the car won't start at all,but I believe that you have a problem with your battery,or the charge system,if there is no charge,and you drain the battery,then car won't start.
