Latest: Wan1977
Overall: 17118
Online Now [30]:
Visitors: 29
Today: 5750
Total: 95566480
Forums › The Car › 206 Problems › 1.6 16v xsi idling issue
Seank791
PostPosted: Wed Feb 25, 2015 11:36 pm Up
Guys just really seeking a second opinion on this one but ive a 206 xsi 1.6 16valve that starts and drives fine but won't hold an idle 9/10 times it will occasionaly idle but any slight throttle movement and it will cut out once i stop applying throttle, I am assuming it is a throttle position sensor as its a fly by wire set up as far as I'm aware, am I right in thinkng this? There's no fault lights on the dash or anything?
And finally if I am right where can I find the part? It's an 01 xsi but ebay isn't any use and neither is the euro car parts app, ive yet to try the local auto factors tough,
efeash
PostPosted: Thu Feb 26, 2015 4:13 pm Up
i've just been having fun with a similar issue on a 1.6 16v cc, i will be either the tps sensor on the throttle body or it will be the accelerator position sensor, after swapping the tps we found out it was the aps.
here is a like to the aps
ebay link for aps
and i think this is the tps
ebay link tps
ash
