Posted: Wed Feb 25, 2015 3:03 pm |
I have had a call today about a little 1.4 8v 2002 petrol that is having a few issues. After a few minutes of idle the car will cut out but always restarts.
If the car is driven reasonably hard the exhaust manifold glows a dull red after about a mile.
He has changed a lot of the sensors on the engine and its on its second catalytic convertor as he thought it was blocked.
This is a little out of my field so I am throwing it open to the experts. I will try to answer any questions
Posted: Wed Feb 25, 2015 3:51 pm |
I had this once on my 1.4, misfire, no power, manifold would glow red after a few miles of driving, turned out to be the coil pack. And the excess fuel was detonating inside the cat causing the glow.
Posted: Wed Feb 25, 2015 3:52 pm |
I would go with either coil park/spark plugs, or an injector sticking open causing over fuel. So check injectors or wiring harness for damage.
Posted: Wed Feb 25, 2015 4:15 pm |
As above, sounds like a misfire of some description
I need a list of what he has and hasnt changed along with where the parts were sourced from
| Team Impossible Possible
Posted: Thu Feb 26, 2015 3:13 am |
Thanks guys will check today
Posted: Tue Mar 17, 2015 7:14 am |
My old car did this (1.4 8v) when my ICV was acting up. Obviously the 3k rpm idle didnt help this at all.....
| Black 206 Gti. Soon to be 2.2 | |
