Posted: Fri Feb 13, 2015 1:59 pm |
Anyone tell me what the code C1380 means?
My ABS light wont go out and thats the code thats coming up and wont clear.
Posted: Fri Feb 13, 2015 2:48 pm |
I believe that relates to a knackered ABS pump
Posted: Sun Feb 15, 2015 3:01 pm |
Is it the ABS pump or the ecu on the side (Or can you not replace just one)?
Posted: Sun Feb 22, 2015 1:21 pm |
Bump
Posted: Sun Feb 22, 2015 2:02 pm |
Check you feeds to the pump, should be two lives and one earth.
If these are good with no volt drop, replace the ABS ECU
| Team Impossible Possible
Posted: Sun Feb 22, 2015 2:40 pm |
Any ideas what wires (pin number or colour and location)?
Posted: Sun Feb 22, 2015 4:14 pm |
PM me the last 8 of the vin and i will let you know
Posted: Fri Mar 13, 2015 2:21 pm |
Quick update:
I removed the headlight so I could get a Torx screw driver onto the 3 screws that hold the ABS ecu to the ABS module and replaced that but it didn't fix the problem.
So next up I fitted my ecu to the ABS module and replaced that. That fixed the problem so I now know that my problem was the ABS module (As my original ecu is fitted to it).
Bled the brakes and I now have working ABS with no warning lights.
