Latest: Mr-Koekwaus
Overall: 17125
Online Now [69]:
Visitors: 68
Today: 3414
Total: 99388679
Forums › The Car › 206 Problems › Anyone is West Midlands got PP2000?
JordHaze
PostPosted: Tue Mar 03, 2015 3:13 pm Up
Hey guys,
Anti-pollution fault again. 4th time now.
I need to find out what it is and fix it before my MOT on the 12th.
Cheers.
My 206 Project Thread
-RAJ-
PostPosted: Wed Mar 04, 2015 5:05 pm Up
does it have to be pp2000, i have a delphi unit which i can put on for £15 if it works. In coventry myself
PostPosted: Fri Mar 06, 2015 3:04 am Up
Have you checked the PP2000 Map,if not,please click on the link below,and check the map
PP2000 Map
Tim
Carlos_WR1
PostPosted: Fri Mar 06, 2015 4:55 am Up
PP2000 Map
Tim
Nearest one is Cheltenham. I know as i have checked before.
JordHaze
PostPosted: Fri Mar 06, 2015 5:20 am Up
Carlos_WR1 wrote:
PP2000 Map
Tim
Cheltenham's quite a drive tbf, I may as we'll pay for the dealer to do it and not waste the petrol...
Elfis-Parsley
PostPosted: Sat Mar 07, 2015 4:42 pm Up
Anti pollution can mean your cat has got clogged up. Take a good run about ten or twelve miles at a good speed but use a lower gear than you usually use, this will burn off the crud and clear the fault, try that before anything else
