Posted: Mon Mar 02, 2015 5:08 am |
Hi my 2003 plate 206 gti (138bhp i think) is making a screeching noise while running, the noise gets louder as the clutch is pushed in. would that be caused by low power steering fluid as it was quite low? also the catalytic converter fault has just come up on display.
Thanks jamie
Posted: Mon Mar 02, 2015 5:36 am |
Thrust bearings about to s**t itself big time. Get it done asap and don't stray too far from home.
Posted: Tue Mar 03, 2015 7:00 am |
as above. normally starts off with a grinding/rushing water noise. once its screeching its on its absolute last legs
| Black 206 Gti. Soon to be 2.2 | |
Posted: Tue Mar 03, 2015 8:05 am |
Mine sounded like that for a few weeks, then it became difficult to select gears.
When the clutch was changed we found it was made of plastic, had actually scored the shaft it was sitting on as it got too hot and fell apart when we took it off.
