Online Now [686]:
Visitors: 685
Today: 225078
Total: 150057263
Forums › The Car › 206 Problems › 206 Cutting Out
206 Cutting Out
tez_69
PostPosted: Tue Mar 03, 2015 8:58 am Up
Hi, I was wondering if anyone could help me. I have recently purchased a 206 1.4 (06 plate) ... it runs well however every so often when I am slowing down and dropping gears whilst approaching traffic lights, junctions or turns etc. the engine just cuts off. It fires straight back up when I turn the key whilst moving and carries on as normal. There is no consistancy or pattern it can run fine for 2 days then do it 3 times in one journey. I have had it plugged in twice by reputable autoelectricians and no errors are showing ... has anyone else had this problem or know what it could be. Thanks in advance.
PostPosted: Tue Mar 03, 2015 3:01 pm Up
well you have a problem with the Idle control valve ,you need to clean your throttle body.
tez_69
PostPosted: Tue Mar 03, 2015 4:04 pm Up
Thanks for response. Will try that tomorrow and see if it cures it.
PostPosted: Tue Mar 03, 2015 4:08 pm Up
An 06 plate doesn't have traction control does it? ESP?
PostPosted: Tue Mar 03, 2015 4:27 pm Up
ESP would be a rare find on a 1.4 but I have seen it a couple of times over the years when the original owner ticked the option box when ordering the car.
PostPosted: Tue Mar 03, 2015 6:27 pm Up
06 plate has an electronic body as far as im aware, i advise you take it to a dealers
PostPosted: Fri Mar 06, 2015 3:42 am Up
Any updates ?
johnpidge
PostPosted: Fri Mar 06, 2015 12:00 pm Up
ICV sounds like it needs a clean??
John
