Online Now [234]:
Visitors: 233
Today: 43472
Total: 142664847
Forums › The Car › 206 Problems › ABS and Traction Control
ECB93
PostPosted: Fri Mar 13, 2015 2:53 am Up
Morning everyone,
Had a little issue where my 206 Gti 138 brings up the abs and traction control light upon staring and beeps to tell me there's an issue. I restart the car and it sorts itself out, no faults. It also comes on when driving occasionally, once again, I just restart the car and it sorts it.
I've plugged the car into my fault reader and there's no codes stored? Also ran the test with the lights on, still no fault codes.
Any ideas?
Thanks.
PostPosted: Fri Mar 13, 2015 8:46 am Up
Use a better code reader, Peugeot Planet will read it perfectly.
Leegsi
PostPosted: Fri Mar 13, 2015 2:19 pm Up
As above.
What code reader did you use as most cheap ones just read the engine codes
PostPosted: Fri Mar 13, 2015 3:16 pm Up
Is the tracking out?
ECB93
PostPosted: Fri Mar 13, 2015 3:47 pm Up
Never had a issue with my fault reader before, works perfect normally but had a proper code reader plugged into today as you said, apparently a speed sensor is fault. I believe I'm right in saying the speed sensor is on the abs and esp are on the same system so it might be that causing the issue? If I'm right let me know though!
There only about £20 from what ive seen so I sort that and see what the result is.
Also I do need to check the tracking as its not perfect, but not fair off. Thanks.
PostPosted: Fri Mar 13, 2015 3:56 pm Up
If it was a front speed sensor fault then check the toothed wheel for the ABS sensor on each driveshaft as there known to crack Wink
ECB93
PostPosted: Fri Mar 13, 2015 4:31 pm Up
Ok thanks, I'll have a good look tomorrow if I get a chance, if not it'll be Monday.
Leegsi
PostPosted: Sun Mar 15, 2015 3:51 pm Up
If the code reader can do live data go for a drive and see what wheel isnt showing any data.
