Posted: Sat Mar 14, 2015 12:12 pm |
Hi, I am new to this site and looking for some help. I have a 1999 206 gti, that wont start. It will turn over but wont fire up. It has new spark plugs and coilpack, so they were immediately ruled out. The problem seems to lie with the fuel pump. I have checked the fuel pump relay under the ecu and this is fine. I have also checked voltage to the pump, fine also. I have removed and bench tested the pump, again this is working. However when trying to fire up the car the fuel pump doesn't work and therefore doesn't send anything to the injectors? I have cleaned all contact terminals but still no luck. If anyone has any suggestions or advice it would be much appreciated? Thanks in advance
Posted: Sat Mar 14, 2015 12:14 pm |
You have checked the RED fuel cut off safety switch in the engine compartment hasn't tripped?
Posted: Sat Mar 14, 2015 12:15 pm |
Hi, yes I have checked this and no good
Posted: Sat Mar 14, 2015 12:17 pm |
Thanks for coming back so quickly BTW
Posted: Sat Mar 14, 2015 12:18 pm |
Key in ignition but switched OFF.
Open the drivers door.
Do you get the key in ignition warning beeps?
Posted: Sat Mar 14, 2015 12:21 pm |
Yeh, the car beeps, so that means the key is recognised, right?
Posted: Sat Mar 14, 2015 12:28 pm |
gogogokarter wrote: |
Yeh, the car beeps, so that means the key is recognised, right? |
Sure sounds like its seeing the key.
Posted: Sat Mar 14, 2015 4:52 pm |
you didnt run the fuel right down prior to this happening by any chance did you?
Just wondering if it picked up crap and is blocking the fuel line? when was the fuel filter last changed also?
Posted: Sat Mar 14, 2015 5:02 pm |
No, I never let the tank run to empty, never let it get below 1/4. I thought they had an in tank fuel filter that is self cleaning?
Posted: Sat Mar 14, 2015 6:13 pm |
I think its the Phase 2 cars that have the self cleaning filter in the tank, The age of your car, being a phase 1, i think it does have a seperate fuel filter. Itll be under the rear arch on the drivers side of the car
Posted: Sat Mar 14, 2015 6:20 pm |
Ok thanks, ill check that next
