Online Now [43]:
Visitors: 42
Today: 78141
Total: 117434901
Forums › The Car › 206 Talk › Is it possible / easier than 140 --> 180?
Gumpy54
PostPosted: Sun Mar 22, 2015 3:18 am Up
Ok, so I currently have a 'V' plate 140 GTi. Runs fine, everything works but its a bit tatty and its my daily driver (I do about 500 miles a week).
Now, for a bit of a starter project, Im thinking of buying a good condition 3 door shell '52 plate or better (GTi 140 preferably), and getting a 180 engine (as there seem to be a lot of them about lately) and slotting her in.
As the '52 plate will more than likely be plex, I am assuming it will literally be plug and play (obviously with the correct ecu / loom from engine)?
TL/DR: Is it less complicated putting a 180 engine into a plex shell, seeing as the plex wiring is in place; than it is putting a 180 engine into a pre-plex shell, as all the wiring would also have to swap over (ball-ache)?
Yes, I know I can buy a cheap 180 these days, but Im after a project, something to keep me busy and so I can clean it up, powdercoat etc etc instead of taking my daily off the road to do it.
Some figures...
Good condition 140 = £650 (https://www.facebook.com/groups/102661519908854/?fref=nf)
180 engine, looms, etc etc. = £400
Time and effort = couple of weeks for swap and tweaking
Decent 180 = £1500
PostPosted: Sun Mar 22, 2015 3:57 am Up
Just buy the 180 and do that up.
206gt160
PostPosted: Sun Mar 22, 2015 4:22 am Up
Get it done, if its a project your after and not just a new gti 180 then it sounds like a good one to me. It should be plug and play with it being plexed.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Sun Mar 22, 2015 5:35 am Up
The 180 has more sensors and a different loom. Much better and cheaper to start with the 180. At the age of these cars there will be lots of things to fix or improve.
