Latest: Mr-Koekwaus
Overall: 17125
Online Now [66]:
Visitors: 65
Today: 22659
Total: 99382341
Forums › The Car › 206 Talk › Removing gti engine
Removing gti engine
Lumpymash
PostPosted: Thu Mar 19, 2015 4:10 pm Up
Hello,
Any info or tips on removing an engine would be very helpful as I'm doing it this weekend.
Anyone got pictures of them doing this in a project thread?
Cheers guys!
(Sorry for all the posts lol)
PostPosted: Thu Mar 19, 2015 4:35 pm Up
Go underneath. Disconnect the engine mount between the sump and subframe. unclip power steering hoses from the engine. Undo the 16mm bolt which holds the gear linkage onto the subframe behind the engine. Those are the main hidden connections. The others are the obvious stuff like the coolant hoses and throttle cable. What you going to do with the air con hoses?
Lumpymash
PostPosted: Thu Mar 19, 2015 5:04 pm Up
Edit,
You mean because of the gas?
Not sure what you mean, I've not done this before
PostPosted: Fri Mar 20, 2015 1:38 am Up
That and will you disconnect or cut the pipes? Or just unbolt the pump from the engine. Accessing the exhaust clamp or manifold can be difficult.
Lumpymash
PostPosted: Fri Mar 20, 2015 2:21 am Up
Didn't really think about the air con. If I can just unbolt it from engine and not touch the pipes ill do that. As he's breaking the car hopefully he won't mind me taking lots of it apart to access what I need to.
