Latest: flipflap
Overall: 17140
Online Now [251]:
Visitors: 250
Today: 90114
Total: 113889957
Forums › The Car › 206 Talk › Second Battery
Second Battery
commandosqueak
PostPosted: Wed Mar 25, 2015 12:22 pm Up
I have seen threads on moving the battery to the boot but nothing on adding a second battery. has anyone done this to there 206?
I plan on adding a second battery with a solar charger for when the engine is off and a battery isolator so i cant flatten my main battery but the alternator will also charge the second battery. I wont be used for starting so should be any massive load on it.
I will run my CB Radio and a 600w transformer so I can run my Toughbook and other charging devices (not all at same time obviously) when I am out and about.
Where would be the best place for a second battery and what kind of battery would be best? would my alternator cope with charging two batteries?
Ideas welcome Smile
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Wed Mar 25, 2015 1:55 pm Up
I would have a look at the system they use for the twin electrics on a towbar. Pretty sure the 12S connection is used for charging the caravan battery
Danpemble
PostPosted: Wed Mar 25, 2015 2:54 pm Up
Yeah I'm quiet interested in this too. I had the same idea, although I had two caravan batteries hooked upto a 3000watt inverter with the parcel shelf being a solar panel. Never had it hooked up the the alternator though, did a fine job for the camping. Not the best idea due to all the extra weight.
commandosqueak
PostPosted: Wed Mar 25, 2015 5:20 pm Up
Two caravan batteries wow that's a bit extreme for my application. It's simple enough to connect it to the main battery just use a isolator, that allows the battery to be charged from the alternator!
I wouldn't want to stick a battery in the cabin area or even the boot for safety reasons so it would have to go under the hood or under the rear of the car somewhere!
commandosqueak
PostPosted: Thu Mar 26, 2015 11:44 am Up
sorry macca i only just spotted your comment. thats not a bad idea as i have a tow bar already! question is where in the hell do i put it?
