Latest: Andyblue64
Overall: 17123
Online Now [234]:
Visitors: 233
Today: 9974
Total: 98765032
Forums › The Car › 206 Problems › Steering Wheel Locked. GTi
lucholussenholff
PostPosted: Sat Mar 28, 2015 6:33 pm Up
Hi,
I have a 206GTi 2003. But the Steering wheel is locked, my little boy was playing and locked the steering without the key. So when I try to unlocked the steering using the keys don't work . I insert the key as usual and move the steering in both sides, and moving the key, but it doesn't work. The car is in economy mode active, I tried to other accumulator but the same. I can't to unlock the steering. Somethimes it was happened to me, but when i move the steering and key with some force It moves but now, not work. Anyone knows a secret for that .. Thanks for your help my i dont move my car two months ago.
PostPosted: Sun Mar 29, 2015 1:38 am Up
Can you actually turn the key?
mtempsch
PostPosted: Sun Mar 29, 2015 1:39 am Up
To the best of my knowledge there is no electricals involved in the steering lock - purely mechanical. That it engaged when the wheel was moved with no key in the ignition is as per design. That one might have to pull on the wheel a bit (nothing excessive though) to be able to turn the key to unlock is also normal, in my experience.
To me it sounds like your lock is broken...
Silvermetallic 2004 206 RC
PostPosted: Sun Mar 29, 2015 2:36 am Up
If the key can turn in the barrel then you can get it in to the service position & extract the barrel.
lucholussenholff
PostPosted: Sun Mar 29, 2015 4:44 pm Up
Hi thanks for your comments..
No I can not turn the key. I try to move the steering wheel at the same time i turn the key, but i cant.
Thanks.
Gumpy54
PostPosted: Mon Mar 30, 2015 1:49 pm Up
The steering wheel in the locked position will still be able to move maybe an inch either way, move it this inch and turn the key. when the steering wheel is locked and hard against the lock it prevents the key from turning.
Hope that makes sense
lucholussenholff
PostPosted: Mon Mar 30, 2015 2:53 pm Up
Thanks..
Well ... this is the usual procedure, but i have tried that .. and no it don't work.
