Latest: Andyblue64
Overall: 17123
Online Now [506]:
Visitors: 505
Today: 31411
Total: 98400151
Forums › The Car › 206 Problems › 206 gti 180 aux belt tensioner
slymambo
PostPosted: Wed May 16, 2012 10:38 am Up
The aux belt on my car is making abit of noise so ive had it looked at and the garage said the tensioner is knackard and they quoted £123 just for the part. Is this right as i thought was abit steep?
Cheers
hi
PostPosted: Wed May 16, 2012 10:42 am Up
If its just the roller wheel / bearing thats noisy on the tensioner you can just change that part.
Peugeot / Citroen dont list the roller for the tensioner but you should find the idler wheel is the same.
Peugeot / Citroen list price for the tensioner unit is £147.76 including the VAT Laughing
slymambo
PostPosted: Wed May 16, 2012 10:51 am Up
do i need something like this? as thats alot cheaper than the garage quoted just for the part?
www.ebay.co.uk/itm/BEL...3369398ed5
cheers
hi
PostPosted: Wed May 16, 2012 1:35 pm Up
That's the one. I've just ordered a new roller for mine because it has a rusty bolt...not sure if its the same roller as the one on the tensioner.
shaunbrook7104
PostPosted: Mon Mar 23, 2015 11:07 am Up
Did this go anywhere guys???
Did the Aux Tensioner fit the RFK engine?? or has anyone found just the roller. I have looked for a power gate one as with the cambelt kit and they do a Aux Belt idler pulley =]
Gumpy54
PostPosted: Tue Mar 24, 2015 9:50 am Up
I got one from Parkers for about £47 quid. Removed the bolt in the centre, and the bolt in the centre of my current one, swapped over the rollers and jobs-a-goodun'.
Took about 1/2 hour including removing / refitting aux belt.
Just remember the bolt in the centre undose the opposite way to normal bolts...
PostPosted: Tue Mar 24, 2015 1:00 pm Up
Left hand thread Wink
shaunbrook7104
PostPosted: Sat Mar 28, 2015 3:58 pm Up
Is there a gates pulley for the tensioner or a complete gates tensioner as I've just put a whole
Hates kit on mine. Timing belt, aux belt, waterpump and all pulleys.
I wanted to keep it all gates Razz
shaunbrook7104
PostPosted: Sat Mar 28, 2015 4:21 pm Up
Is the gti 180 six tensioner the same as the gti 138 tensioner??
As gates do just the pulleys but can only find it for a description of 2.0 16v?
