Posted: Wed Apr 01, 2015 10:24 am |
Hi guys!
Steering feels pretty stiff on slow/very slow speeds.
is it just my car or 180 in general?
all good on higher speeds but slow speeds it feels a bit too stiff. Makes me wonder if power steering is adjusting with the speed or not. Shouldnt GTI 180 have adjusting one? (not sure what it's called)
any ideas?
Posted: Wed Apr 01, 2015 11:06 am |
The 180's steering is more responsive at higher rpms and feels heavy at lower rpms, its designed this way.
Posted: Wed Apr 01, 2015 4:20 pm |
Ohh, so its meant to be that stiff on low rpms?
I mean one doesn't smoothly roll around on a parking lot one-handed on low rpms.
That stiff, is this normal?
Btw, what do you think if I go from 205 wide tires to 215, will it feel even stiffer with only 10mm added wideness?
Posted: Wed Apr 01, 2015 8:24 pm |
Check the tyre pressures run 38/34 psi
Fnt/bk
. If you try to turn fast the steering goes stiff. depending on you speed ..
| If it aint broke dont fix it ! | |
