Posted: Tue Apr 07, 2015 11:06 am |
Hi,
I've owned my Pug since May last year, and its been running fine since then, last Thursday I parked it up (had been running absolutely fine), and left it until the Sunday when i tried to start it up again it wouldn't start!
If you turn the key you can hear it trying to go but it just wont start.
I had the breakdown out, they said it could either be the immobiliser or the injectors. Apparently fuel is going through, but it just isn't starting up...
A neighbour had a code reader and it gave out the following codes: P1352, U0028, P0092, U1003. Whether these have got anything to do with it not starting I don't know...
At the moment, it's in a garage and the mechanic has said I need the ECU to be removed and sent for testing, not sure about this!
Has anybody had anything similar happen? Im a bit lost, and dreading some big bills!
Thanks for your time.
Posted: Tue Apr 07, 2015 1:41 pm |
Have you checked the battery? When it doesn't start do you hear a rapid ticking sound upon turning the key?
| I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport | |
Posted: Tue Apr 07, 2015 2:09 pm |
The battery is fine, and no there's no rapid ticking sound, like you turn the key and it makes the kind of normal turning over sound, but doesn't start...
Posted: Tue Apr 07, 2015 2:22 pm |
Fault code: P1352
After sales description of the fault code: Engine preheating : Fault on the pre-heating relay or glow plugs
Have you checked your glow plugs?
Posted: Tue Apr 07, 2015 3:18 pm |
I wouldn't know how to (diesel newbie here...), I'll get the garage to have a look tomorrow!
