Posted: Sat Apr 04, 2015 4:33 am |
Posted: Sat Apr 04, 2015 6:55 am |
Very common problem, I've had I happen on a few 206's and it's also known to happen on the 306's as well.
Posted: Sat Apr 04, 2015 8:28 am |
And are there any known solutions to this problem?;)
Posted: Sat Apr 04, 2015 9:40 am |
So the captive nut is spinning round?
Posted: Sat Apr 04, 2015 12:19 pm |
Yes. But the main problem is that when i manage to tighten the mount it somehow unscrews and loosens after a ride or two so it starts to move around again... Is it a good idea to take this nut out, remove the bracket and just put washer with some nylon nut and thread-lock... ??
Posted: Sat Apr 04, 2015 1:07 pm |
Looks like its time for the mig welder
Posted: Sat Apr 04, 2015 1:54 pm |
You think i should leave the bracket on? It is very damaged though... Or just weld the nut on the place?;)
Posted: Sat Apr 04, 2015 9:10 pm |
Or you can put a nut and washer onto that pertruding bolt
Posted: Wed Apr 08, 2015 4:27 pm |
Removed everything and tried with nut and washer. Washer was still hitting the old nut bracket so i put only nylon nut now and so far so good ;))
Thanks all for help!! i appreciate it!!:))
Cheers!
