Latest: flipflap
Overall: 17140
Online Now [224]:
Visitors: 223
Today: 7158
Total: 113914575
Forums › The Car › 206 Problems › 1.4 hdi loud tapping knocking? crank shaft pully??
Danpemble
PostPosted: Sun Apr 05, 2015 9:30 am Up
Now I've done a little research and come to the conclusion that the crank pully is on it's way out. I've took a quick video just to see what you think. How much of a job is it to replace? Also just driving home my speedo just died. Only the speed dropped to 0mph While all els was working.
Peugeot 206 1.4 hdi loud tapping crank shaft pully: youtu.be/HEZu2fcBgm4
PostPosted: Sun Apr 05, 2015 3:51 pm Up
Definitely on its way out. Your tensioner pulley seems to have a fair amount of movement as well
Danpemble
PostPosted: Tue Apr 07, 2015 2:48 am Up
Yeah I wasn't sure if the Crank shaft pulley was making the tensioner move, or should that still be solid?
PostPosted: Tue Apr 07, 2015 3:42 am Up
Should be solid. I'd change that as well. Also new belt wouldn't hurt
Danpemble
PostPosted: Tue Apr 07, 2015 4:36 am Up
Ah ok thanks. I'll do tensioner too. Yeah the belt is going to be changed. Any tips? if the weather is ok then il be doing this on the weekend
gazza82
PostPosted: Tue Apr 07, 2015 1:41 pm Up
Pulley has a rubber centre ... that breaks up and you get a clonking sound ...
Swap out the water pump while you are doing belts ... it's driven off the cam belt too.
No tips apart from take your time and double, triple check everything. It's easier than the 138bhp twin cam if that's any consolation and I've done both! Bit more room for your hands in the 1.4hdi bay too.
PostPosted: Tue Apr 07, 2015 3:38 pm Up
No need to to touch timing by to swap the pulley?
Danpemble
PostPosted: Wed Apr 08, 2015 1:39 pm Up
No that's what I was thinking. The aux belt runs the a/c, power steering and alternator right?
gazza82
PostPosted: Wed Apr 08, 2015 3:55 pm Up
Right!
PostPosted: Wed Apr 08, 2015 4:10 pm Up
gazza82 wrote:
Right!
No need to change water pump then?
Danpemble
PostPosted: Fri Apr 10, 2015 11:12 am Up
Well I managed to put a new pulley on this afternoon and we'll the sound is gone!
Was a really easy job didn't take long at all. I managed to borrow the local garages impact gun. Cost just over 100 for the pulley and belt. Thanks
PostPosted: Fri Apr 10, 2015 11:36 am Up
How was the tensioner. Good job.
Danpemble
PostPosted: Fri Apr 10, 2015 11:58 am Up
I didn't get the tensioner in the end. There wasn't any play in it or in any of the pulleys for that matter.
