Latest: SA01
Overall: 17138
Online Now [194]:
Visitors: 194
Today: 7151
Total: 112304111
Forums › The Car › 206 Talk › 206 gti vibratechnics lower engine mount
pumba
PostPosted: Sat May 02, 2015 3:24 am Up
Hi guys anyone know the lower engine mount size please. Im looking to fit a vibratectics lower mount as I think mines naffed, the rubber looks to have split a bit an my engine seems to rock back an forth a bit on idle.whilst driving the gear stick shakes a bit an if i pull off a bit harsh an change gear fast from 1st to 2nd it's sometimes hard or wont go in gear first time
thanks in advace
PUMB@206
PostPosted: Sat May 02, 2015 9:51 am Up
The VB mount will fit the 206 as I have one fitted.
pumba
PostPosted: Sat May 02, 2015 10:42 am Up
Thanks mate is the lower mount 70mm
PUMB@206
