Posted: Fri Apr 17, 2015 2:17 am |
Hi, I have a jingling sound coming from my front OS front wheel sometimes when going over uneven ground etc. It kind of sounds like someone 'jingling change in their pocket'
Any ideas.
PS. I have checked my pockets but they are empty
Posted: Fri Apr 17, 2015 2:47 am |
Have you run over a cat and it's bell has caught around the suspension?
Could be a number of things. Brake pads loose in the caliper, worn suspension bushes/ball joints
Posted: Fri Apr 17, 2015 5:33 am |
It's probably the lock washer on the ball joint. If the tab gets separted from were it seats the washer is loose and jingles on uneven surfaces as you described.
Posted: Tue Apr 21, 2015 12:54 am |
checked yesterday and the brake pads are rattling in the caliper. New brake pads then....
Posted: Tue Apr 21, 2015 3:46 am |
jamie-38-206 wrote: |
checked yesterday and the brake pads are rattling in the caliper. New brake pads then.... |
I had the same problem. A new set of pads does NOT cure it, you need the fixing kit. There are a set of retaining clips which hold the pads firmly in place. £20ish from peugeot or £9.99 on ebay. Theyre listed for the 306/205
| Black 206 Gti. Soon to be 2.2 | |
Posted: Tue Apr 21, 2015 8:03 am |
A decent set of pads should come with the springs, it's just a lot of people are too lazy to fit them or don't understand how they clip onto the pad.
This is what the clips look like
www.eurocarparts.com/e...d64&000036
Posted: Tue Apr 21, 2015 8:53 am |
macca1411 wrote: |
www.eurocarparts.com/e...amp;000036 |
Ahh my mistake, I was thinking of my rear pads! Yes retaining clips should definitely be with the new FRONT pads
