Latest: tc.206
Overall: 17147
Online Now [63]:
Visitors: 62
Today: 17747
Total: 116437899
Forums › The Car › 206 Problems › front right wheel movement
Project2062014
PostPosted: Thu Apr 16, 2015 1:42 pm Up
I've had a slight squeeks at random times . ive removed the front wheel to change the bearing and I've noticed --
The other side looks like this
How is so much play possible? I cannot even find any play ..
Project2062014
PostPosted: Thu Apr 16, 2015 3:16 pm Up
Will a hub off a 1.9d 1999 Fit ?
I cannot remove the bearing with a puller kit . But I've got a 1999 206 on the drive .. Anyone many thanks
HowlingMadMurdock
PostPosted: Thu Apr 16, 2015 3:20 pm Up
I would go to the local scrap yard or eBay and buy a hub assembly from the exact model. It will be cheap and guaranteed to fit
I ain't nuts, I'm condiments, I've been promoted
PostPosted: Thu Apr 16, 2015 3:35 pm Up
What wheels are you running on?
Is the tyre the right size?
Project2062014
PostPosted: Thu Apr 16, 2015 3:42 pm Up
There all 17/40/205 rollin on the original vortex 17's .
HowlingMadMurdock
PostPosted: Thu Apr 16, 2015 4:57 pm Up
Have you had it lowered? Something is hitting that shock and it shouldn't.
Any tyre damage? I would have thought so.
Springs and shocks ok?
I would have thought you would hear noise with that damage to the shock
Project2062014
PostPosted: Fri Apr 17, 2015 3:33 pm Up
So I replaced the bearing today . I found the right damper was sat 5mm further down than the left damper in the hub.
There is a small location plate welded on each damper by pro sport to sit in the hub .. The right hub has a slight dink on each side at the back of the hub where ithe location plate sits in .
so the damper sits 5mm lower because of the dink .
I can say then hub must of been in a smash UP @some point ..
I spot welded it and grinded it back perfect .
Car now sits perfect to the other side ..
I didnt notice before DOH !
Leegsi
PostPosted: Sun Apr 19, 2015 12:16 pm Up
Nice to get to the bottom of it
