Latest: evert
Overall: 17112
Online Now [88]:
Visitors: 87
Today: 3880
Total: 93726078
Forums › The Car › 206 Problems › Rocker cover gasket
Rocker cover gasket
CraygL
PostPosted: Mon Apr 27, 2015 4:09 am Up
Hey all, been losing oil for the last month or so and have just been keeping it topped up. It looks like my rocker cover gasket is leaking (pics attached). Am I right in thinking this is an easy job on this car? Anything I should look out for? cheers!
Edit: forgot to say, it's a 2001 1.1 lx
RichardEke
PostPosted: Mon Apr 27, 2015 6:34 am Up
Hi there, you're right it is easy.
2 x 10mm nuts holding the rocker cover on, just be careful as you lift it off as there are 2 spacers that sit between the rocker cover and the baffle plate, they usually like to roll around.
2 x 10mm bolts/studs holding the coil pack on
And maybe a rag of some kind to clean the 2 surfaces when going back together.
Oh and removing the engine breather.
&don't over tighten when going back together as this could cause leaks.
Hope this helps.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
CraygL
PostPosted: Mon Apr 27, 2015 7:31 am Up
Hope this helps.
Regards, Richard.
Cheers buddy! didn't think i'd have to remove the coil pack but looking at it again there's not much space between the two.
Thanks for the help, ordering the gasket now!
-Craig
cainw1
PostPosted: Mon Apr 27, 2015 8:48 am Up
Yeah its not a tricky job. I did it on my 180 without any difficulty at all. Make sure you put some grease on before you put the new gasket on.
RichardEke
PostPosted: Mon Apr 27, 2015 8:50 am Up
Not sure if you have to but i did just to make sure the new gasket was seated properly, also gave me space to wipe the mating surfaces a little easier.
Regards, Richard.
