Latest: Andyblue64
Overall: 17123
Online Now [298]:
Visitors: 297
Today: 28154
Total: 97975473
Forums › The Car › 206 Talk › 180 Brakes
180 Brakes
Vexs
PostPosted: Mon Apr 27, 2015 1:07 am Up
So I'm finally planning to get round to fitting the new Mtec grooved and drilled discs I've got.
Now I've looked up the whole ABS issue needing PP to bleed the system but is that really the case?
I've read a lot of conflicting comments on here in regards to needing it/not needing it from members who are very much in the know (baring in mind these are 5 year old posts & comments)
Is it just safer to use PP or can the Gunson kit be just as effective?
I really don't need the ball ache of it messing up when I need it for work at the moment and as I don't have PP I may just have a local pug place do it instead.
My GTI 180
My Old 1.4 8v
206gt160
PostPosted: Mon Apr 27, 2015 7:14 am Up
I have never used pp2000 on my pug over the last 6 years and my brakes have always been perfect, I use the bleed easy kit using tyre pressure with no problems at all. Starting furthest away moving to the next furthest away from the front of the car/brake master cylinder when bleeding.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
broadblaster
PostPosted: Mon Apr 27, 2015 12:28 pm Up
If your only changeing the discs and pads then you should not need to bleed the system anyway.
on a back road playing
206gt160
PostPosted: Mon Apr 27, 2015 12:50 pm Up
I agree! What He Said
I always flushed out the old brake fluid every 12 months, and split the calipers down and greased them up and if needed changed seals when changing disks and pads. Probably unnecessary on a 12 month basis but it's a quick easy job and the brakes are the most important part of the car.
broadblaster
PostPosted: Mon Apr 27, 2015 2:57 pm Up
206gt160 wrote:
i would say imho that is a tad ocd Shocked but its never a bad thing to go right through them, they do recommed a fluid change every 2 yrs anyway.
But i bet there are thousands of cars on the road that have never been done since the car was new.
206gt160
PostPosted: Mon Apr 27, 2015 4:23 pm Up
OCD or doing a proper job, I would say the latter. I know my brakes are as good as they could ever be and will not be binding, or wearing the pads unevenly. Such an easy job that will give you better braking efficiency so why not.
Pp4811
PostPosted: Mon Apr 27, 2015 4:33 pm Up
So it is possible to bleed the brakes without pp?? That is great news if so. Would that be the same if the abs pump is changed?
206 gt - gone (sadly)
206 gti 2003 - Sahara yellow - gone
206 gti 2002 - silver - present car!!
206gt160
PostPosted: Mon Apr 27, 2015 5:05 pm Up
I'm not too sure about if its the same for changing the abs pump I have not had to do that "yet", but yes you can definitely bleed the brakes with out pp2000 because I have done it a countless amount of times. Infact I need to do it this week with fitting the Gti6 Front caliper and disk setup.
