Latest: Mr-Koekwaus
Overall: 17125
Online Now [505]:
Visitors: 504
Today: 52777
Total: 99883333
Forums › The Car › 206 Problems › Does anyone know the length of the drop links on the Gti
206gt160
PostPosted: Thu Apr 30, 2015 1:35 am Up
Im currently looking at buying some Motorsport drop links but I am not with the car to measure their length and whether they are 10 or 12mm stud size?
If anyone could help me out I would be very greatful.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Thu Apr 30, 2015 3:46 pm Up
Go on. What's the point?
206gt160
PostPosted: Thu Apr 30, 2015 3:57 pm Up
Well the point is I want some uprated adjustable motorsport drop links, so I need to know the length of the original ones and also the thread size due to not having the car in front of me to check myself.
Project2062014
PostPosted: Thu Apr 30, 2015 4:29 pm Up
How do they adjust ? I've got some new at home . Il post my findings when I return .
206gt160
PostPosted: Thu Apr 30, 2015 4:41 pm Up
Thanks project.. they are very similar to a turnbuckle if you know what they are. They are heavy duty the ones I am looking at buying so they will stand upto track days a hell of a sight better than the oem units. It also gives you adjustment over your front antiroll bars slightly. Interested in seeing how lengthening and shortening them affects laps on the track. I know some people dissaprove of adjustable units but I ant to find out for myself what advantages and disadvantages are.
Project2062014
PostPosted: Thu Apr 30, 2015 6:19 pm Up
Looking at 10mm stud size .
Overall length is 370mm .. Stud to stud distance from the centre point to centre point of the stud . 335 mm ..
206gt160
PostPosted: Fri May 01, 2015 2:11 am Up
Thanks a lot pal thats just what I needed to know.
Project2062014
PostPosted: Fri May 01, 2015 3:43 am Up
How do they adjust & what affect does the adjustment have ?
Just read your post Doh .
I guess it would just put a pre load on the anti roll .
Make the ride slightly stiffer on turn in? ..
just get a thicker anti roll bar ?? Is that possible ??
206gt160
PostPosted: Fri May 01, 2015 6:48 am Up
For now I'm going to test out the drop links pal. Yes your right they put a preload on the anti roll bars and will make it stiffer on turn in etc.
You can get uprated bars for other car so I presume you can for the 206, also I think the gti 180 may be slightly thicker than the gti bar. Not 100 percent on that.
206gt160
PostPosted: Fri May 01, 2015 6:52 am Up
Is it definitely metric and not imperial? Did you use digital calipers to measure
oldskoolz
PostPosted: Fri May 01, 2015 7:01 am Up
180 definitely has a thicker ARB front and rear
Black 206 Gti. Soon to be 2.2
PostPosted: Fri May 01, 2015 7:18 am Up
Depends on the year of manufacture, Early 138's had a 20mm anti roll bar, 180's had a 21mm throughout production and later 138's had a 22mm bar. Wink
206gt160
PostPosted: Fri May 01, 2015 7:36 am Up
I have the earlier model 99 reg, what year are the 22mm bars on?
Where you stating front arb or rear arb
PostPosted: Fri May 01, 2015 7:38 am Up
You'r will be the 20mm, I can't remember the changeover year but I know my 2003 GTi has the 22mm
And front ARB this is relating to.
PostPosted: Fri May 01, 2015 7:48 am Up
So little benefit from adjustable drop links but no mention of doing significant stuff like uprating torsion bars and the rear ARB. Don't waste your money.
