Posted: Thu Apr 02, 2015 3:50 pm |
This washer goes between the oil cooler, further up.
I wonder if I replace it if it needs to be torqued up?
Posted: Fri Apr 03, 2015 3:42 am |
Well done
Posted: Fri Apr 03, 2015 2:29 pm |
Nevermind, I tried all the things, I changed 3 gaskets, I torqued it up, down, no way. After a week the oil leak comes back.
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Fri Apr 03, 2015 3:58 pm |
Wash the oil off with a jet wash and then recheck after a drive to see where it's coming from
| You never really learn to swear until you learn to drive | |
Posted: Tue Apr 07, 2015 6:01 pm |
Shall hopefully be getting my new washer Thursday. When refitting is the a torque setting for the big bolt that screws through the oil cooler?
Posted: Wed Apr 08, 2015 7:11 am |
mattymj wrote: |
Shall hopefully be getting my new washer Thursday. When refitting is the a torque setting for the big bolt that screws through the oil cooler? |
I would imagine there is considering there is a gasket behind it. Try it as hand tight plus a quarter turn and see from there, most rubber seals will be crushed beyond this point.
| Black 206 Gti. Soon to be 2.2 | |
Posted: Wed Apr 08, 2015 1:23 pm |
Would it hurt to put sump sealant on the outer edges?
Posted: Thu Apr 09, 2015 8:38 am |
I have the new seal. Peugeot state a 8 nm tightening! Isn't that hand tight?
Posted: Thu Apr 09, 2015 8:48 am |
mattymj wrote: |
I have the new seal. Peugeot state a 8 nm tightening! Isn't that hand tight? |
Without a torque wrench its hard to say
Posted: Thu Apr 09, 2015 8:57 am |
Could go for hand tight plus a 1/4 turn!
Posted: Thu Apr 09, 2015 10:38 am |
Not too much difference
Posted: Thu Apr 09, 2015 12:13 pm |
I found the cooler had lines on it so I hand tightened it then aligned it square
Posted: Fri Apr 10, 2015 9:02 am |
Steve206 wrote: |
Would it hurt to put sump sealant on the outer edges? |
Shoot me
| If it aint broke dont fix it ! | |
Posted: Fri Apr 10, 2015 9:25 am |
Posted: Fri Apr 10, 2015 2:15 pm |
So did it sort your leak?
