Latest: sparrowdclxvi
Overall: 17139
Online Now [145]:
Visitors: 144
Today: 30498
Total: 113639334
Forums › The Car › 206 Problems › help please. gearbox/clutch whining sound video
Danpemble
PostPosted: Sat May 16, 2015 5:24 am Up
hey everyone! Kind of need some help and advice. Was just driving home when I noticed this horrible whine noise, thought it might of been a belt. On closer inspection the sound is definitely coming from the gear box. Ive record what it sounds like. It does stop when the clutch gets pressed. Thanks anyone who can help
m.youtube.com/watch?v=...e=youtu.be
ukskater01
PostPosted: Sat May 16, 2015 5:53 am Up
Sounds like the thrust bearing, does the clutch slip? You will be best to get the clutch replaced at the same time
Danpemble
PostPosted: Sat May 16, 2015 6:11 am Up
Clutch seems fine. Had it changed 20,000 miles ago. I'm sure the thrust bearing got change too as it was really worn.
Danpemble
PostPosted: Sat May 16, 2015 7:27 am Up
So had another look and it does still make that whine noise when the clutch is down and casting
