Online Now [1109]:
Visitors: 1109
Today: 187591
Total: 150490549
Forums › The Car › 206 Problems › Releasing Steering Wheel Connector Blocks
ospreys
PostPosted: Fri May 15, 2015 6:42 am Up
Hi
I'm trying to fix indicator stalk problem and have taken airbag off but can't work out how to release the connector blocks. I'm not a mechanic, hence the reason I can't see how to do this. It looks flimsy so I don't want to break it.
Image of the blocks that I want to figure out how to release.
Hope someone can help. Many thanks.
www.dropbox.com/s/yblb...0.jpg?dl=0
Vexs
PostPosted: Fri May 15, 2015 8:09 am Up
www.206info.co.uk/Foru...61376.html
My GTI 180
My Old 1.4 8v
ospreys
PostPosted: Fri May 15, 2015 4:10 pm Up
onMany thanks. Figured it out in the end.
Thank you!
Sim
PostPosted: Fri May 15, 2015 5:01 pm Up
In a pre-plexed, I just removed the column cowlings secured by two torxes, to get to the stalks. Indicator block was easy to remove, steering wheel and airbag all left in place
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
