Online Now [670]:
Visitors: 669
Today: 178110
Total: 151954280
Forums › The Car › 206 Problems › Oil filter quandry
Oil filter quandry
vartegrich
PostPosted: Sat May 23, 2015 4:57 am Up
I'm just in the process of doing an oil change on a 2003 1.4 lx and the replacement oil filter is 70mm long which is shorter than the one coming off the car. However, the one coming off looks like it's been compressed whilst in the housing. Searching the web, I can see two different sizes of filter with the larger sizes having what looks like a plastic plunger sticking out of them.
The filter housing is approximately 90mm tall, but the old filter doesn't have the plunger thing.
Could someone shed some light on which might be the correct filter to use?
PostPosted: Sat May 23, 2015 6:51 am Up
I think it's 8mm. You should be able to pick one up from Halfords.
I have a double ended sump/gearbox tool that you turn with a 19mm socket or spanner
similar to this
or this is the socket
