Latest: Mr-Koekwaus
Overall: 17125
Online Now [73]:
Visitors: 72
Today: 24819
Total: 99384500
Forums › The Car › 206 Talk › Is my engine tilting?
Mangie1
PostPosted: Mon Jun 22, 2015 5:25 am Up
Hi
I wonder if my engine is tilting backwards in to the car.
In the second Picture you can se that there is a smal gap between the bush and the metal. In the third picture there is no gap and the bush is different.
The engine is pushing on this bush continuously and even more under accerelation.
Is it supposed to be like this?
206 GTI 180
southwestchap
PostPosted: Mon Jun 22, 2015 6:16 am Up
Catch hold the engine and see if you have excessive movement.
My bets on being the bottom engine mount could be worn.
Mangie1
PostPosted: Mon Jun 22, 2015 6:26 am Up
The engine does not move much. The lower engine mount is fine.
PostPosted: Mon Jun 22, 2015 10:24 am Up
It's fine.
