Latest: sparrowdclxvi
Overall: 17139
Online Now [160]:
Visitors: 159
Today: 38521
Total: 113486540
Forums › The Car › 206 Talk › Correct front brake pads
pug_206_uk
PostPosted: Wed Jun 03, 2015 5:26 pm Up
I have a 1.4 hdi and I've upgraded my front brakes from a 206 2.0 gti and all
I can remember is it was around 1999 to 2002, I've seen some brake pads on the following link
pages.ebay.com/link/?n...0728645460
I've been looking and noticed different thickness I just don't want to buy the wrong set, I know the front discs size is 266mm
Thanks in advance
Peugeot 206 1.4 HDI - July 2013 - Present
PostPosted: Thu Jun 04, 2015 12:26 pm Up
Do you have thick discs or the thinner ones? Measure the height of the discs too and compare that to measurements from euro car parts.
