Latest: Mr-Koekwaus
Overall: 17125
Online Now [152]:
Visitors: 150
Members: 1
Today: 8248
Total: 99367983
Forums › The Car › 206 Problems › Pulling right on lift off
neilneil2000
PostPosted: Fri May 01, 2015 3:37 pm Up
I have recently bought my red 206GTi and have a bit of a steering issue... When I put the power down there is a slight pull to the left and if I suddenly release the throttle there is a definite pull right.
Any ideas?
Is this going to cost me a million pounds?
pug206lx
PostPosted: Fri May 01, 2015 5:18 pm Up
I had this on a diesel but really bad, I spent a lot of money trying to sort it and in the end it was the driveshafts. You need a good garage to check everything over really, it's worth it.
neilneil2000
PostPosted: Sat May 02, 2015 1:15 am Up
Thanks for the reply. I am trying to learn as much as I can as the car is a little project for me. Such a shame there is no Haynes manual for the GTi.
2000 (W) 206 GTi pre-plex RFR EW10J4
RichardEke
PostPosted: Sat May 02, 2015 1:28 am Up
Morning,
Does it pull either way when braking?
Just thinking if one of the front calipers wasn't releasing all the way it might cause it. Easy to check just lift that wheel and give it a spin, should be equal both sides.
Just an idea
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
PostPosted: Sat May 02, 2015 2:54 am Up
Very long thread on here where someone had different dimensions on their bottom wishbones. That really was a bugger to diagnose.
Use the search function and you will find many threads with different causes.
Sim
PostPosted: Sat May 02, 2015 5:11 am Up
Online
www.206info.co.uk/Foru...54530.html
up to a point where i even created a poll Smile it won't cost you millions to diagnose and fix the culprit , good luck!
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
neilneil2000
PostPosted: Sat May 02, 2015 12:04 pm Up
Thanks all, I will work through the list and let you know how I get on
neilneil2000
PostPosted: Sun May 10, 2015 2:38 pm Up
Looks like I have a slow puncture so will get that seen to first. Both wishbones are the same dimensions but they are different brands. No sign of any play in the bushes or bearings though.
neilneil2000
PostPosted: Sun May 31, 2015 12:27 pm Up
Going in to the garage this week for an offside wishbone replacement...fingers crossed this fixes it!
Sim
PostPosted: Sun May 31, 2015 12:57 pm Up
Online
Ensure both wishbones are 100% look-alike
EV
GTC VXR (sold)
neilneil2000
PostPosted: Sat Jun 06, 2015 5:11 am Up
It only bloody worked didn't it!
I now have a car that drives in a straight line AND has a decent idle!!! WHOOOOP
However I did just over-torque by boss in a bout of excitement and cracked the cast iron...whoops
PostPosted: Sat Jun 06, 2015 7:53 am Up
There is a Haynes manual that covers the 206 GTi. It's just a shame they did the engine work on a 307 because they don't consider the access problems in the tighter engine bay of the 206.
