Latest: Mr-Koekwaus
Overall: 17125
Online Now [64]:
Visitors: 63
Today: 25329
Total: 99385010
Forums › The Car › 206 Problems › Caliper slider pin stiff when bolt is tight
liam1988
PostPosted: Thu Jun 04, 2015 2:19 pm Up
Hey guys, I thought I would change my caliper because it failed on a binded brake, When changing the caliper and putting the new caliper on I noticed that the old caliper slider pins were stiff as hell when the bolts into them are fully tight, but if I slightly loosen them they go back and forth as they should. The pins are all lubed up fine and not corroded. Anyone else have this problem? I thought maybe they could be slightly bent?
Smile
PostPosted: Thu Jun 04, 2015 3:27 pm Up
One of mine is like this so it's slightly harder to spin one wheel than the other. I can only assume it's slightly bent. A new slider might fix it.
PostPosted: Fri Jun 05, 2015 3:06 am Up
Everytime you replace the brake pads,the pins need to be cleaned and use silicone grease to lubricate it,and this will make the move smoother Smile and easier Smile
liam1988
PostPosted: Fri Jun 05, 2015 6:37 am Up
Thanks for the reply guys, ordered a new set of slider pins for the caliper.... praying this solves it..
Liam
Smile
PostPosted: Fri Jun 05, 2015 6:53 am Up
Mine are spotless with fresh grease and they are still stiff once tight.
