Latest: kemppu
Overall: 17142
Online Now [106]:
Visitors: 105
Today: 5415
Total: 114044778
Forums › The Car › 206 Problems › scrapping noise with wheel rotation
trevoroq
PostPosted: Sat Jun 06, 2015 12:16 am Up
Hi, I have a 2005 1.6 16v 206cc, when I start to move there is a scrapping noise coming from the front nearside , it goes in time with wheel rotation and gets faster as speed increases until at a certain speed , I can't hear it. Turning does not make much difference but when I depress the clutch and coast the noise stops.There is no noise with just the engine running, and it makes no difference if you are turning. I have tried moving the front wheels but can feel no movement, and get no vibration in the steering at 10mph or 70mph. If anyone has any ideas I would be grateful Thanks .
PostPosted: Sat Jun 06, 2015 1:48 am Up
Sounds like a wheel bearing or possibly drive shaft.
PostPosted: Sat Jun 06, 2015 3:28 pm Up
You need new front discs and pads.
PostPosted: Sat Jun 06, 2015 3:32 pm Up
Or a clutch release bearing.
PostPosted: Sat Jun 06, 2015 3:35 pm Up
you can left the car up using the jack,and move the wheel by hand,and listen what cause the sound.
Mangie1
PostPosted: Mon Jun 22, 2015 6:39 am Up
How would bad discs and pads make that noise, and why would it dissaperar when the clutch is down?
Project2062014
PostPosted: Mon Jun 22, 2015 4:32 pm Up
If it disappears when the clutch is pressed then it's the clutch release bearing. can you feel the vibration though the clutch?
If not probably a wheel bearing !!
