Latest: sparrowdclxvi
Overall: 17139
Online Now [300]:
Visitors: 299
Today: 20131
Total: 112704155
Forums › The Car › 206 Problems › The bad idle is back...Noooooo!
neilneil2000
PostPosted: Sun Jun 07, 2015 4:24 pm Up
Having celebrated my success of having a perfect idle, I took my car out for a spin yesterday and it stalled twice Sad
Same symptoms as before - when the revs drop down quickly it can't seem to recover quick enough to stop itself stalling.
I am reckoning Lambda sensor is the next thing to test.
skybluebert
PostPosted: Sun Jun 07, 2015 10:02 pm Up
I had trouble with a lumpy idle nd lack of power, my coil pack was sendin an electric charge into the engine block
dmsempire
PostPosted: Mon Jun 08, 2015 5:44 pm Up
Read somewhere on this forum, when everything else fails, coil pack, spark plugs, etc, try replacing the knock sensor, got one today myself for my lumpy idle, ill post after replacing it.
oldskoolz
PostPosted: Tue Jun 09, 2015 2:41 am Up
keep us posted on the knock sensor
Black 206 Gti. Soon to be 2.2
Carlos_WR1
PostPosted: Tue Jun 09, 2015 6:49 am Up
Been there, done that, replaced a knock sensor and it didnt help with my idle issues, my issue ended up being a dodgy engine mount replaced it and everything has been fine since.
neilneil2000
PostPosted: Tue Jun 09, 2015 3:48 pm Up
Which mount was it?
2000 (W) 206 GTi pre-plex RFR EW10J4
Carlos_WR1
PostPosted: Tue Jun 09, 2015 4:22 pm Up
well on my particular car, both engine mounts. When my mechanic did my cambelt, he noticed the top engine mount was split right through so that got replaced, made the car a bit smoother but there was still an issue. As well as the bad idle i noticed when putting the car into reverse o clunking noise and there was also an intermittent starting issue. Replaced the lower engine mount (torque bush) and the issue went away, car ran a lot smoother.
