Forums › The Car › 206 Problems › ball joint |
Posted: Tue Jun 16, 2015 3:26 pm |
This is how I used to get mine out.
Posted: Fri Jun 19, 2015 12:40 pm |
All that will usually achieve is a broken plank and whiplash when you stamp on the floor, its definately easier with 2 people.
I prefer to jack up the leg until just before the spring starts to fight back then get a mate to wobble the leg into position while i negotiate the ball joint into it.
Alone its got to be easiest to undo the wishbone bolts, connect the balljoint then negotiate the wishbone back in. Pain in the a**e, im just about to replace both of mine cant wait lol
Posted: Fri Jun 19, 2015 4:51 pm |
Stamp? It's a lot more controlled than that.
