Latest: Mr-Koekwaus
Overall: 17125
Online Now [273]:
Visitors: 272
Today: 50212
Total: 99816791
Forums › The Car › 206 Problems › Cooling fan problems
Go to page Previous  1, 2
Sim
PostPosted: Sun Jul 05, 2015 3:26 pm Up
So what made your low speed fan come on? What did you fix? I'm curious as per this thread Smile
I'm driving around without any fan at all (nor A/C), so can't help with A/C, sorry
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
l3ighl3igh
PostPosted: Mon Jul 06, 2015 12:14 am Up
I had corrosion in both relay boxes. Stupidly, when first looking for the problem and not fully understanding how the fan works, we found one wire that had turned to dust, fixed it and put everything back together.
Thanks for your replies. Will have the A/C serviced tomorrow and hope for the best Smile
jbhensoniii
PostPosted: Thu Feb 25, 2016 9:30 pm Up
where were the wires corroded? Do you have pictures? I want to know where exactly to check for corrosion?
PostPosted: Thu Feb 25, 2016 9:46 pm Up
Check them right at the end where they connect to the relay.
Page 2 of 2
