Latest: Mr-Koekwaus
Overall: 17125
Online Now [111]:
Visitors: 110
Today: 23319
Total: 99408536
Forums › The Car › 206 Problems › name that sound
name that sound
Mangie1
PostPosted: Mon Jun 22, 2015 8:51 am Up
vid.me/e/JJZ7
There is a "rotating" sound and I dont konow what its coming from. It is in all gears, even reverse. Stearing left or right has no effect on the sound. The sound gets louder when I accelerarte. When I press the clutch it disapears completley
I have had the car for 2 years now and the sound have always ben there.
In this 2 years I have changed:
Front brake pads
clutch
release bearing
drive chaft
sloposse
PostPosted: Mon Jun 22, 2015 4:10 pm Up
Output shaft bearing or diff bearing, could also be the intermediate bearing on the long driveshaft.
Bit of a guess however I have a 205 that has developed a very similar noise and that disappears when I dip the clutch
Could also be a belt rubbing on a plastic cover so check those.
Mangie1
PostPosted: Thu Jul 09, 2015 7:15 am Up
The sound comes from the right side of the car. I have changed the bearing on the long driveshaft but that did not help.
I know that my VVT is bad, can that make a noise?
If the Engine mounts is bad, could that make this sound if the engine is tilting?
