Latest: Mr-Koekwaus
Overall: 17125
Online Now [53]:
Visitors: 51
Members: 1
Today: 30958
Total: 99416127
Forums › The Car › 206 Problems › Brakes ridiculously slack....
Gezrick
PostPosted: Tue Jun 23, 2015 11:24 am Up
Hi everyone, I'm new to this forum but just thought it might be a good place to get a pre-evaluation before heading to the garage.
I have a 206 1.4i lx 1999 and there's something up with my brakes. They work fine, no grinding or any feedback that feels out of place and I can stop the car with them easily enough, but they don't seem to kick in until my foot is nearly at the floor. I may be new to driving but this seems unusual to me.
I've check the fluid level and it's actually a little over maximum, I can't imagine that's causing it but I don't know enough to say for sure.
Any suggestions on what it could be would be much appreciated.
Thanks in advance,
Gez
PostPosted: Tue Jun 23, 2015 1:22 pm Up
Normally on a drum brake car like this will be, the rear shoes can go out of adjustment due to the automatic adjustors being rubbish & stopping working.
Normally a rear brake strip down, clean, adjust & grease will restore the correct operation.
Might be worth asking your mechanic to also check the front brakes condition while its on the ramp then change the brake fluid with a pressure bleed as well so you know the braking system is sorted.
Gezrick
PostPosted: Tue Jun 23, 2015 1:39 pm Up
I thought the drums might have something to do with it. Thank you Smile
PostPosted: Tue Jun 23, 2015 1:43 pm Up
I had similar where my foot went to the floor before stopping the car and the lining material had parted company with the shoe causing excessive movement in the drum
