Posted: Mon Jun 03, 2013 1:10 pm |
if i buy a second hand key fob off ebay, can i program it in with peugeot planet or not? i mean i know you cant program a used bsi unit, but is the key the same? as ive only got 1 key with the car
Posted: Mon Jun 03, 2013 1:23 pm |
It will need a blank immo chip installed and there's a slight risk of it not working and/or getting 'locked-out' of the BSI and making your car a non-starter.
Posted: Mon Jun 03, 2013 1:29 pm |
when you buy a used key,you will need a new immo chip as V9977 said,but if you want to have a key with 2 buttons working,then you need to make sure the the circuit board "Letter" in the end of the Serial number matches the one you have,and ofcourse you need the 4 digit security code so you can program both keys on your car
Posted: Mon Jun 03, 2013 1:36 pm |
Pre plex or multiplex
If you get the right circuit board, yes. I think there are 3 for multiplex and they depend on if front fogs are fitted for some strange reason.
Some BSIs are programmed to accept a certain number of remotes. I think you need to delete all keys and then reprogram the keys that you have.
The new key will be useless to start the car though unless you get a virgin transponder chip and pair that with the car. These chips can only be used once, so if one comes with the used key, it can't be reprogrammed.
Posted: Mon Jun 03, 2013 2:09 pm |
I hate to burst the bubble. I was unsuccessful I bought a second hand board, same number as the board in my first key, sorted the chip out,, and Boom didnt work!
and the worst thing is, i did everything right which is stated above.
Posted: Mon Jun 03, 2013 2:19 pm |
i had this post on the peugeot forum for 2 days and i had no replies, and straight off you have answered my question, thanks guys, i only bought the car to sell on, i will give the new owner this problem.
Posted: Thu Jun 13, 2013 6:07 pm |
iainlovatt wrote: |
and the worst thing is, i did everything right which is stated above. |
same thing happened to me.. on PP the car is picking up the signal but doesnt recognise it to open or lock the doors.
| GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow | |
Posted: Fri Jun 14, 2013 9:56 am |
A new multiplexed remote key isn't that expensive from Peugeot, why do people bother with the hassle of 2nd hand keys
Posted: Tue Jun 25, 2013 1:26 pm |
Ok, so I got a blank key with a virgin chip, I also have pp2000, any guides of how to program keys in?
Posted: Fri Aug 16, 2013 3:06 pm |
hey
just wondered in anyone knows what key fob i need for a 1.1 206 with front fogs
thanks Sam
Posted: Fri Aug 16, 2013 3:57 pm |
scove1994 wrote: |
hey
thanks Sam |
I would say either 6554YR or 6554YV
Posted: Sun Aug 09, 2015 2:16 pm |
I have a damaged peugeout partner key - does anyone have a used peugeot key I can buy to replacedamaged battery contacts
